Saltar al contenido principal
Xiaomi Redmi Note Front-Facing Camera Replacement
Qué necesitas
  1. Xiaomi Redmi Note Front-Facing Camera Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure the Xiaomi Redmi Note is powered off before removing the battery.
    • Insert the plastic opening tool between the charging port and the rear case.
    • Pry the end of the rear case up from the charging port.
  2. Xiaomi Redmi Note Front-Facing Camera Replacement: paso 2, imagen 1 de 2 Xiaomi Redmi Note Front-Facing Camera Replacement: paso 2, imagen 2 de 2
    • Run the plastic opening tool along the seam on the side of the phone to remove the rear casing.
  3. Xiaomi Redmi Note Front-Facing Camera Replacement: paso 3, imagen 1 de 2 Xiaomi Redmi Note Front-Facing Camera Replacement: paso 3, imagen 2 de 2
    • Locate the indentation at the bottom of the battery.
    • Place a finger in the indentation and lift up to remove the battery.
  4. Xiaomi Redmi Note Front-Facing Camera Replacement, Midframe: paso 4, imagen 1 de 2 Xiaomi Redmi Note Front-Facing Camera Replacement, Midframe: paso 4, imagen 2 de 2
    • Remove twelve 3.5mm Phillips #00 screws from the midframe.
  5. Xiaomi Redmi Note Front-Facing Camera Replacement: paso 5, imagen 1 de 2 Xiaomi Redmi Note Front-Facing Camera Replacement: paso 5, imagen 2 de 2
    • Insert a plastic opening into the seam between the midframe and the bottom frame of the phone.
    • Run the plastic opening tool along the seam.
    • Pry up the midframe with the plastic opening tool.
    • Once the midframe has been sufficiently lifted with the tool, place a hand underneath the edge to lift the entire component out of the frame.
    • There will be snapping sounds as the clips on the midframe disconnect from the phone.
  6. Xiaomi Redmi Note Front-Facing Camera Replacement, Front-Facing Camera: paso 6, imagen 1 de 3 Xiaomi Redmi Note Front-Facing Camera Replacement, Front-Facing Camera: paso 6, imagen 2 de 3 Xiaomi Redmi Note Front-Facing Camera Replacement, Front-Facing Camera: paso 6, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers to lift the retaining flap of the zero insertion force (ZIF) connector to the upright position.
    • Use tweezers to pull the ribbon cable out of the ZIF connector.
    • Remove the front-facing camera from the motherboard.
Conclusión
2 personas más completaron esta guía.
Equipo
Cal Poly, Team S22-G4, Livingston Spring 2017 Miembro de Cal Poly, Team S22-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G4
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 21
Todo El Tiempo: 1,441
