Saltar al contenido principal
Xiaomi Redmi Note 4X Battery Replacement
Qué necesitas
  1. Xiaomi Redmi Note 4X Battery Replacement, Removing the back cover: paso 1, imagen 1 de 3 Xiaomi Redmi Note 4X Battery Replacement, Removing the back cover: paso 1, imagen 2 de 3 Xiaomi Redmi Note 4X Battery Replacement, Removing the back cover: paso 1, imagen 3 de 3
    • The first thing we have to do is use a pry tool to remove the back cover (make sure to remove the sim tray first)
  2. Xiaomi Redmi Note 4X Battery Replacement, Removing the Battery: paso 2, imagen 1 de 3 Xiaomi Redmi Note 4X Battery Replacement, Removing the Battery: paso 2, imagen 2 de 3 Xiaomi Redmi Note 4X Battery Replacement, Removing the Battery: paso 2, imagen 3 de 3
    • Now we have to remove the battery, luckily the Battery can be removed first after taking the back cover off.
  3. Xiaomi Redmi Note 4X Battery Replacement, Reassembly: paso 3, imagen 1 de 2 Xiaomi Redmi Note 4X Battery Replacement, Reassembly: paso 3, imagen 2 de 2
    • Now you can insert your new battery, pop the back cover on, and your good to go! Congratulations, you've just replaced your phone's battery.
Conclusión
Congratulations on repairing your smartphone!
Una persona más ha completado esta guía.
Isaiah Kochis
Miembro Desde 09/02/20
205 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 15
Ultimos 30 días: 86
Todo El Tiempo: 2,400
