Introducción
Use this guide to remove the screen assembly of your Xiaomi Redmi 2 for repair or replacement of any parts attached.
Qué necesitas
Use the flat end of the spudger to remove the back panel from the mid-frame and front body.
Using the nylon or metal spudger, gently pry the front speaker from the screen assembly.
Remove the 2.9 mm Phillips #000 screw that holds the PCB circuit board to the screen assembly.
31 personas más completaron esta guía.
2 comentarios
Touch is not working after replacing full LCD, Brought new display & changed again but no luck, Display is okay but touch not working.
