Saltar al contenido principal
Xiaomi ROBOROCK S5 Top Buttons Replacement
Qué necesitas
  1. Xiaomi ROBOROCK S5 Top Buttons Replacement, Top Buttons: paso 1, imagen 1 de 3 Xiaomi ROBOROCK S5 Top Buttons Replacement, Top Buttons: paso 1, imagen 2 de 3 Xiaomi ROBOROCK S5 Top Buttons Replacement, Top Buttons: paso 1, imagen 3 de 3
    • Turn off your Roborock S5.
    • Place it on a flat work surface.
    • Use an opening tool to carefully pry under the section of the top panel with the buttons.
    • Gently pull upward to snap the panel off the top of the vacuum. It is secured in place by five snaps that you will need to release to remove the panel.
    • This can take some force, and the snaps can be quite loud. Be careful not to break the panel.
  2. Xiaomi ROBOROCK S5 Top Buttons Replacement: paso 2, imagen 1 de 2 Xiaomi ROBOROCK S5 Top Buttons Replacement: paso 2, imagen 2 de 2
    Herramienta utilizada en este paso:
    Tesa 61395 Tape
    $5.99
    Comprar
    • Flip the panel over.
    • Peel the button pad off of the panel and set it aside.
    • The pad is secured with a strong adhesive. If there is remaining glue on the panel, it should be strong enough to hold the new button pad. In case the new button pad doesn't adhere properly, you can use a thin double-sided tape like Tesa tape to help secure it.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 12
Todo El Tiempo: 103
