Saltar al contenido principal
Xiaomi Mi Pad Motherboard Replacement
Qué necesitas
  1. Xiaomi Mi Pad Motherboard Replacement, Rear Case Assembly: paso 1, imagen 1 de 1
    • Remove the micro SD card slot from the left side of the device using either the metal pin included with the device or a SIM card eject tool.
  2. Xiaomi Mi Pad Motherboard Replacement: paso 2, imagen 1 de 2 Xiaomi Mi Pad Motherboard Replacement: paso 2, imagen 2 de 2
    • Use a plastic opening tool and/or opening pick to gently pry the back panel away from the device. Work your way around the device, slowly increasing the gap.
    • The back panel has small clips and light adhesive that easily releases from the device.
  3. Xiaomi Mi Pad Motherboard Replacement, Motherboard: paso 3, imagen 1 de 2 Xiaomi Mi Pad Motherboard Replacement, Motherboard: paso 3, imagen 2 de 2
    • Remove the twelve 3 mm Phillips #00 screws on the upper cover of the device.
  4. Xiaomi Mi Pad Motherboard Replacement: paso 4, imagen 1 de 1
    • Remove the upper cover from the device.
  5. Xiaomi Mi Pad Motherboard Replacement: paso 5, imagen 1 de 1
    • Remove the two 3.0 mm Phillips #00 screws securing the motherboard to the device.
  6. Xiaomi Mi Pad Motherboard Replacement: paso 6, imagen 1 de 2 Xiaomi Mi Pad Motherboard Replacement: paso 6, imagen 2 de 2
    • Disconnect the six ribbon cables attached to the motherboard using a plastic opening tool.
  7. Xiaomi Mi Pad Motherboard Replacement: paso 7, imagen 1 de 1
    • Carefully remove the motherboard from the device.
Conclusión
12 personas más completaron esta guía.
Kiefer Sivitz
Miembro Desde 09/03/15
560 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 12-5, Blackwell Fall 2015 Miembro de USF Tampa, Team 12-5, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G5
3 Miembros
13 Guías creadas
4 comentarios
It's my email
amaank987321.msk@gmail.com
MSK DIGITAL MEDIA - Contestar
i'm looking to buy a motherboard for my died mi pad and i couldn't find it any were. Do you know were i can bay one , please help
Vasile Postolache - Contestar
I want mi pad mother board
Where I buy
Sunil - Contestar
where can i buy matherboard for Xiaomi Mi Pad 4 ?
guyv1975 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 43
Todo El Tiempo: 6,576
