Saltar al contenido principal
Xiaomi Mi Pad Headphone Jack Replacement
Qué necesitas
  1. Xiaomi Mi Pad Headphone Jack Replacement, Rear Case Assembly: paso 1, imagen 1 de 1
    • Remove the micro SD card slot from the left side of the device using either the metal pin included with the device or a SIM card eject tool.
  2. Xiaomi Mi Pad Headphone Jack Replacement: paso 2, imagen 1 de 2 Xiaomi Mi Pad Headphone Jack Replacement: paso 2, imagen 2 de 2
    • Use a plastic opening tool and/or opening pick to gently pry the back panel away from the device. Work your way around the device, slowly increasing the gap.
    • The back panel has small clips and light adhesive that easily releases from the device.
  3. Xiaomi Mi Pad Headphone Jack Replacement, Headphone Jack: paso 3, imagen 1 de 2 Xiaomi Mi Pad Headphone Jack Replacement, Headphone Jack: paso 3, imagen 2 de 2
    • Remove the twelve 3.0 mm Phillips #000 screws on the upper cover of the device.
  4. Xiaomi Mi Pad Headphone Jack Replacement: paso 4, imagen 1 de 1
    • Remove the upper cover from the device.
  5. Xiaomi Mi Pad Headphone Jack Replacement: paso 5, imagen 1 de 1
    • Use a plastic opening tool to pull up and remove the headphone jack from the upper cover.
    • Insert the corner of a plastic opening tool into the port of the headphone jack for easier removal.
Conclusión
Una persona más ha completado esta guía.
Rene Mendoza
Miembro Desde 09/03/15
311 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 12-5, Blackwell Fall 2015 Miembro de USF Tampa, Team 12-5, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G5
3 Miembros
13 Guías creadas
Un comentario
And where to buy? :-(
marcusvoag - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 11
Todo El Tiempo: 2,441
