Saltar al contenido principal
Xiaomi Mi Pad Front Camera Replacement
Qué necesitas
  1. Xiaomi Mi Pad Front Camera  Replacement, Rear Case Assembly: paso 1, imagen 1 de 1
    • Remove the micro SD card slot from the left side of the device using either the metal pin included with the device or a SIM card eject tool.
  2. Xiaomi Mi Pad Front Camera  Replacement: paso 2, imagen 1 de 2 Xiaomi Mi Pad Front Camera  Replacement: paso 2, imagen 2 de 2
    • Use a plastic opening tool and/or opening pick to gently pry the back panel away from the device. Work your way around the device, slowly increasing the gap.
    • The back panel has small clips and light adhesive that easily releases from the device.
  3. Xiaomi Mi Pad Front Camera  Replacement, Front Camera: paso 3, imagen 1 de 2 Xiaomi Mi Pad Front Camera  Replacement, Front Camera: paso 3, imagen 2 de 2
    • Remove the twelve 3.0 mm Phillips #000 screws on the upper cover of the device.
  4. Xiaomi Mi Pad Front Camera  Replacement: paso 4, imagen 1 de 1
    • Remove the upper cover from the device.
  5. Xiaomi Mi Pad Front Camera  Replacement: paso 5, imagen 1 de 1
    • Use a plastic opening tool to gently disconnect the front-facing camera from the motherboard.
  6. Xiaomi Mi Pad Front Camera  Replacement: paso 6, imagen 1 de 1
    • Carefully remove the front camera from the device.
Conclusión
Rene Mendoza
Miembro Desde 09/03/15
311 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 12-5, Blackwell Fall 2015 Miembro de USF Tampa, Team 12-5, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G5
3 Miembros
13 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 12
Todo El Tiempo: 833
