Saltar al contenido principal
Xiaomi Mi Pad Battery Replacement
Qué necesitas
  1. Xiaomi Mi Pad Battery Replacement, Rear Case Assembly: paso 1, imagen 1 de 1
    • Remove the micro SD card slot from the left side of the device using either the metal pin included with the device or a SIM card eject tool.
  2. Xiaomi Mi Pad Battery Replacement: paso 2, imagen 1 de 2 Xiaomi Mi Pad Battery Replacement: paso 2, imagen 2 de 2
    • Use a plastic opening tool and/or opening pick to gently pry the back panel away from the device. Work your way around the device, slowly increasing the gap.
    • The back panel has small clips and light adhesive that easily releases from the device.
  3. Xiaomi Mi Pad Battery Replacement, Battery: paso 3, imagen 1 de 2 Xiaomi Mi Pad Battery Replacement, Battery: paso 3, imagen 2 de 2
    • Remove the twelve 3.0 mm Phillips #000 screws on the upper cover of the device.
  4. Xiaomi Mi Pad Battery Replacement: paso 4, imagen 1 de 1
    • Remove the upper cover from the device.
  5. Xiaomi Mi Pad Battery Replacement: paso 5, imagen 1 de 2 Xiaomi Mi Pad Battery Replacement: paso 5, imagen 2 de 2
    • Use a plastic opening tool to disconnect the three ribbon cable connectors.
    • If you're only going to replace the battery, you should only need to disconnect the smallest ribbon cable that connects the battery to the motherboard.
  6. Xiaomi Mi Pad Battery Replacement: paso 6, imagen 1 de 1
    • Carefully pry around the perimeter of the battery with a plastic opening tool to loosen the adhesive securing the battery to the device.
    • Be gentle when removing the battery, as lithium-ion batteries should not be bent or punctured.
  7. Xiaomi Mi Pad Battery Replacement: paso 7, imagen 1 de 3 Xiaomi Mi Pad Battery Replacement: paso 7, imagen 2 de 3 Xiaomi Mi Pad Battery Replacement: paso 7, imagen 3 de 3
    • If you disconnected all three connectors, the charging port ribbon cable may have a small amount of adhesive securing it to the battery. Gently pry the cable free of the battery and lift the battery up and out of the device.
Conclusión
18 personas más completaron esta guía.
Jessica
Miembro Desde 09/03/15
713 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 12-5, Blackwell Fall 2015 Miembro de USF Tampa, Team 12-5, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G5
3 Miembros
13 Guías creadas
12 comentarios
Hi
Great Tutorial, but where can i buy a replacement Battery?
THANKS
Marcel - Contestar
Go to Leamington road and you will get it
affan -
Go to Leamington road mumbai
affan -
Where to purchase the Mi Paf battery?
Dino Bay - Contestar
Please please make a video for it. I need it desperately.
Man Mohan Shukla - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 37
Ultimos 30 días: 139
Todo El Tiempo: 23,596
