Saltar al contenido principal
Xiaomi Mi Note Rear camera Replacement
Qué necesitas
  1. Xiaomi Mi Note Rear camera Replacement, Battery: paso 1, imagen 1 de 2 Xiaomi Mi Note Rear camera Replacement, Battery: paso 1, imagen 2 de 2
    • Use your suction cup to grip the back of the phone. Once the suction cup is secure, pull back with moderate force and the back plate should snap free.
  2. Xiaomi Mi Note Rear camera Replacement: paso 2, imagen 1 de 3 Xiaomi Mi Note Rear camera Replacement: paso 2, imagen 2 de 3 Xiaomi Mi Note Rear camera Replacement: paso 2, imagen 3 de 3
    • Once the back plate is off you will need to detach the frames that hold in the battery. Locate and remove the screws (Screws are marked in the image). You can then pull the frame off with ease once the screws have been removed.
    • Remove the six 3.5mm Phillips #000 black screws using a securing part of the back panels.
    • Remove the seven 2.5mm Phillips #000 black screws securing part of the back panels.
    • Remove the five 2mm Phillips #000 silver screws securing the remaining back panels.
  3. Xiaomi Mi Note Rear camera Replacement: paso 3, imagen 1 de 1
    • Use a nylon spudger to pry upwards to detach the ribbon that's connecting the battery to the motherboard.
  4. Xiaomi Mi Note Rear camera Replacement: paso 4, imagen 1 de 2 Xiaomi Mi Note Rear camera Replacement: paso 4, imagen 2 de 2
    • Insert a nylon or metal spudger underneath the battery at any point. Then slide the spudger around all the edges to loosen it. The battery can now be easily lifted out of the frame.
    • Glue will be holding down the backside of the battery.
  5. Xiaomi Mi Note Rear camera Replacement, Rear camera: paso 5, imagen 1 de 1
    • Use a plastic spudger to detach the remaining ribbon from the motherboard.
  6. Xiaomi Mi Note Rear camera Replacement: paso 6, imagen 1 de 2 Xiaomi Mi Note Rear camera Replacement: paso 6, imagen 2 de 2
    • Use tweezers to detach the small ribbon on the left side located near the volume buttons as well as the microphone cord located on the right side along the frame.
    • When detaching the ribbon on the left use minimal force to prevent damage.
  7. Xiaomi Mi Note Rear camera Replacement: paso 7, imagen 1 de 2 Xiaomi Mi Note Rear camera Replacement: paso 7, imagen 2 de 2
    • Use a tweezer to lift and remove the motherboard from the frame.
    • Be sure that the Dual SIM card and tray has been removed.
  8. Xiaomi Mi Note Rear camera Replacement: paso 8, imagen 1 de 1
    • Use tweezers to slide the ribbon to the right out of the insert as shown in the image.
Conclusión
5 personas más completaron esta guía.
Equipo
USF Tampa, Team 1-6, Sullivan Fall 2015 Miembro de USF Tampa, Team 1-6, Sullivan Fall 2015
USFT-SULLIVAN-F15S1G6
4 Miembros
6 Guías creadas
Un comentario
With the onset of the new year, the world of smartphones is looking forward to the launch of Xiaomi Mi6, the next flagship launch in the series of Mi phones.
The Mi 5 received a lot of positive feedback when it launched last year, so we can expect that the Mi6 is going to be even better than its predecessor.
You can check out my site http://mi6splus.com/xiaomi-mi-6-features... for more info about the same.
Rick Halder - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 4,371
