Introducción
Use this guide to replace your Xiaomi Mi Note's front facing camera.
Qué necesitas
Locate the hole for the Dual SIM SD card on the left side of the phone.
Use your suction cup to grip the back of the phone. Once the suction cup is secure, pull back with moderate force and the back plate should snap free.
Once the back plate is off you will need to detach the frames that hold in the battery. Locate and remove the screws (Screws are marked in the image). You can then pull the frame off with ease once the screws have been removed.
Remove the six 3.5mm Phillips #000 black screws using a securing part of the back panels.
Remove the seven 2.5mm Phillips #000 black screws securing part of the back panels.
Remove the five 2mm Phillips #000 silver screws securing the remaining back panels.
Use a spudger to pry upwards and detach the three ribbons that are connected to the motherboard.
4 personas más completaron esta guía.
