Introducción
This guide will show how to access and replace the motherboard on the Xiaomi Mi A2. Before replacing the motherboard remember to be very careful and organized with each step it takes to remove the pre-existing motherboard.
Qué necesitas
Grab a suction cup tool and place it near the bottom of the phone.
Pull up on the suction cup to slightly lift the LCD Panel from the body of the phone.
Starting from the bottom, slide in a plastic opening tool between the gap of the LCD and the phone.
Using a combination of the plastic opening tool and picks, slide around the gaps to unhook the clips, unhinging the panel from the body of the phone.
Flip the phone screen towards the bottom of the device and lay the screen facing down.
Using a plastic spudger remove the battery connector ribbon cable by getting underneath the connector and gently lifting it off.
Using a plastic sudger remove the screen connector ribbon cable by lifting from the underneath.
After you remove the ribbon cable the panel should be free to remove and replace.
Remove the two 3.8mm Phillips #0 screws holding down the lower metal bracket.
Herramienta utilizada en este paso:Tweezers$4.99
On the bottom of the battery are two pull tabs. They are glued on to the battery similarly like a sticker.
To remove the battery pull these pull tabs downwards. WARNING: proceed with extreme caution, avoid bending or puncturing the battery.
You can use tweezers to lift the pull tabs from the battery. Pull downwards and the adhesive will slowly be removed from the battery.
Using a plastic spudger, gently separate the front camera ribbon cable from the motherboard.
Using a plastic spudger, gently disconnect the Motherboard to SUB board flex connector from the motherboard.
Using a plastic spudger, gently disconnect the fingerprint sensor connector from the motherboard.
5 personas más completaron esta guía.
