Introducción
Use this guide to remove or replace a broken or defective fingerprint sensor in the Xiaomi Mi 8.
You’ll need replacement adhesive to reattach components when reassembling the device.
Qué necesitas
Apply a heated iOpener to the rear glass to loosen the adhesive beneath the edges. Apply the iOpener for at least two minutes.
Secure a suction handle to the lower edge of the rear glass, as close to the edge as possible.
Lift the rear glass with the suction handle to create a gap between the glass and the frame.
Insert an opening pick into the gap.
Slide the opening pick to the bottom right corner of the phone.
Insert a third opening pick at the bottom left corner.
Start to slide the opening pick from the bottom left corner along the side of the Xiaomi Mi 8 to cut the adhesive.
As the adhesive cools down it gets harder to cut. If necessary use your iOpener to reheat it.
Leave the opening pick in the top left corner to prevent the adhesive from resealing.
Apply a heated iOpener to the rear glass to loosen the adhesive beneath the fingerprint sensor. Apply the iOpener for at least two minutes.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
2 personas más completaron esta guía.
Un comentario
This is so informative, one of my friend had this issue so I bought the replacement part followed this steps and its quiet easier to replace the flex cable.
