Introducción
Batteries are meant for reuse, but if they don't recharge then they may need to be replaced. This guide will show you how to safely remove your mobile device's battery.
Use a pin or paper clip to insert in the hole on the side of the phone next to the micro SIM cardholder to remove the tray.
Remove the SIM card tray from the Xiaomi Mi 4 and store it somewhere safe.
Using the flat metal spudger and curved metal spudger, make a wedge between the plastic back cover and the inner frame
Using the second spudger, slowly work your way around the perimeter of the device
As the back cover is almost completely removed, use the suction-cup tool to remove the plastic cover without damaging the back
Use a 000 phillips head screwdriver to remove the 10 1.2mm phillips head screws in the plastic frame that hold the motherboard and battery.
Use a 000 phillips head screwdriver to remove the 3 0.5mm phillips head screws in the plastic frame that hold the motherboard and battery.
Use the small plastic opening tool and place it in the slot on the bottom right corner of the inner frame and carefully pry it off.
Use tweezers to gently disconnect the connections that run across the battery and are connected to the motherboard.
Proceed to gently remove the tape like connector from the battery until it is completely off.
Use tweezer to disconnect battery’s wire from the motherboard.
47 personas más completaron esta guía.
24 comentarios
Sir, I accidentally put a hole in battery while removing. Will this create a problem/explosion..
Hey Apawilo. A punctured battery has potential to be very dangerous (Fire, harmful chemicals, etc), so please make sure to dispose of it at the nearest e-waste recycling site.
sir i am charging my phone but its percentage is not increasing ....this is a battery problem
im having the similar problem, when charging power increase slower and the consumption is faster than usual. please advice. thanks
Zeff Soo -
