Saltar al contenido principal
Xiaomi Air 12 Speaker Replacement
Qué necesitas
  1. Xiaomi Air 12 Speaker Replacement, Rear Casing: paso 1, imagen 1 de 1
    • Orient the computer so the Xiaomi logo is at the bottom of the device.
  2. Xiaomi Air 12 Speaker Replacement: paso 2, imagen 1 de 3 Xiaomi Air 12 Speaker Replacement: paso 2, imagen 2 de 3 Xiaomi Air 12 Speaker Replacement: paso 2, imagen 3 de 3
    • Insert the plastic opening tool underneath the top-middle rubber covering and lift upwards to reveal the hidden screw.
  3. Xiaomi Air 12 Speaker Replacement: paso 3, imagen 1 de 2 Xiaomi Air 12 Speaker Replacement: paso 3, imagen 2 de 2
    • Remove the eight 3 mm screws using the Torx T5 driver by inserting the screwdriver into each screw and rotating counterclockwise.
  4. Xiaomi Air 12 Speaker Replacement: paso 4, imagen 1 de 3 Xiaomi Air 12 Speaker Replacement: paso 4, imagen 2 de 3 Xiaomi Air 12 Speaker Replacement: paso 4, imagen 3 de 3
    • Insert the plastic opening tool into each side of the computer and push the tool downwards to pop open the back cover.
    • You will hear popping noises as you remove the cover.
  5. Xiaomi Air 12 Speaker Replacement: paso 5, imagen 1 de 2 Xiaomi Air 12 Speaker Replacement: paso 5, imagen 2 de 2
    • Remove the back of the laptop by gently lifting the casing upwards.
  6. Xiaomi Air 12 Speaker Replacement, Speaker: paso 6, imagen 1 de 2 Xiaomi Air 12 Speaker Replacement, Speaker: paso 6, imagen 2 de 2
    • Remove the white and black speaker wires from the black tabs by pulling upwards from the device.
  7. Xiaomi Air 12 Speaker Replacement: paso 7, imagen 1 de 2 Xiaomi Air 12 Speaker Replacement: paso 7, imagen 2 de 2
    • Gently pull the speaker connector out from the connection point using your hand.
  8. Xiaomi Air 12 Speaker Replacement: paso 8, imagen 1 de 3 Xiaomi Air 12 Speaker Replacement: paso 8, imagen 2 de 3 Xiaomi Air 12 Speaker Replacement: paso 8, imagen 3 de 3
    • Remove the left speaker module by pulling the panel up from the device.
    • Repeat the same process for the right speaker module.
    • Left and Right speaker modules are denoted by an "L" and "R" respectively.
    • There will be a slight adhesive underneath the module.
Conclusión
2 personas más completaron esta guía.
Hannah Kwan
Miembro Desde 04/18/18
839 Reputación
5 Guías creadas
Equipo
Cal Poly, Team S18-G4, Livingston Spring 2018 Miembro de Cal Poly, Team S18-G4, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G4
4 Miembros
20 Guías creadas
6 comentarios
Thanks for the tutorial! But where can i buy replacement speakers? My right speaker is overdriving all the time now, giving me a lot of loud buzz noises.
Nicolai - Contestar
The same for me. I’d like to replace the speakers because one of them is “crackling/vibrating”, but i don’t know where to buy them…
Maniac 45 - Contestar
same problem, mine at >50% vibrating very bad
isman87 - Contestar
have you found them? i need those too
Giorgio Pianesi -
Hello, i love this laptop and its been my companion for almost 3 years think the audio input jack got grounded because i heard a creaking sound when i inserted a metallic headset jack, the device was charging when it happened. Now the audio output from the audio jack port is like a minus one or somewhat instrumental. Any suggestions what to do?
James Prae Liclican - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 21
Todo El Tiempo: 1,024
