Saltar al contenido principal
Xiaomi Air 12 SSD Replacement
Qué necesitas
  1. Xiaomi Air 12 SSD Replacement, Rear Casing: paso 1, imagen 1 de 1
    • Orient the computer so the Xiaomi logo is at the bottom of the device.
  2. Xiaomi Air 12 SSD Replacement: paso 2, imagen 1 de 3 Xiaomi Air 12 SSD Replacement: paso 2, imagen 2 de 3 Xiaomi Air 12 SSD Replacement: paso 2, imagen 3 de 3
    • Insert the plastic opening tool underneath the top-middle rubber covering and lift upwards to reveal the hidden screw.
  3. Xiaomi Air 12 SSD Replacement: paso 3, imagen 1 de 2 Xiaomi Air 12 SSD Replacement: paso 3, imagen 2 de 2
    • Remove the eight 3 mm screws using the Torx T5 driver by inserting the screwdriver into each screw and rotating counterclockwise.
  4. Xiaomi Air 12 SSD Replacement: paso 4, imagen 1 de 3 Xiaomi Air 12 SSD Replacement: paso 4, imagen 2 de 3 Xiaomi Air 12 SSD Replacement: paso 4, imagen 3 de 3
    • Insert the plastic opening tool into each side of the computer and push the tool downwards to pop open the back cover.
    • You will hear popping noises as you remove the cover.
  5. Xiaomi Air 12 SSD Replacement: paso 5, imagen 1 de 2 Xiaomi Air 12 SSD Replacement: paso 5, imagen 2 de 2
    • Remove the back of the laptop by gently lifting the casing upwards.
  6. Xiaomi Air 12 SSD Replacement, SSD: paso 6, imagen 1 de 2 Xiaomi Air 12 SSD Replacement, SSD: paso 6, imagen 2 de 2
    • Detach the white and black speaker wires by pulling them from the small black tabs along the perimeter of the metal bracket.
  7. Xiaomi Air 12 SSD Replacement: paso 7, imagen 1 de 2 Xiaomi Air 12 SSD Replacement: paso 7, imagen 2 de 2
    • Remove the 1.5mm screw using the JIS #00 screwdriver.
  8. Xiaomi Air 12 SSD Replacement: paso 8, imagen 1 de 2 Xiaomi Air 12 SSD Replacement: paso 8, imagen 2 de 2
    • Lift the SSD up from the device and gently pull the SSD from the laptop.
Conclusión
Hannah Kwan
Miembro Desde 04/18/18
839 Reputación
5 Guías creadas
Equipo
Cal Poly, Team S18-G4, Livingston Spring 2018 Miembro de Cal Poly, Team S18-G4, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G4
4 Miembros
20 Guías creadas
Un comentario
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 53
Todo El Tiempo: 4,175
