Saltar al contenido principal
Xelio P900A-BK Front Facing Camera Replacement
Qué necesitas
  1. Xelio P900A-BK Front Facing Camera Replacement, Front Facing Camera: paso 1, imagen 1 de 1
    • Remove the two 5.4mm bottom screws.
    • Set aside.
  2. Xelio P900A-BK Front Facing Camera Replacement: paso 2, imagen 1 de 3 Xelio P900A-BK Front Facing Camera Replacement: paso 2, imagen 2 de 3 Xelio P900A-BK Front Facing Camera Replacement: paso 2, imagen 3 de 3
    • Insert a plastic opening tool between the screen and the rear case and carefully pry the tablet open.
    • Gently work your way around the entire tablet and do not force the case open prematurely.
    • You will hear the plastic latches pop free.
  3. Xelio P900A-BK Front Facing Camera Replacement: paso 3, imagen 1 de 1
    • Remove the connection between the camera and the motherboard.
    • Open the black ribbon holder then remove the ribbon from its connection.
  4. Xelio P900A-BK Front Facing Camera Replacement: paso 4, imagen 1 de 1
    • Remove the tape covering the front facing camera entirely to expose one of the motherboard screws.
  5. Xelio P900A-BK Front Facing Camera Replacement: paso 5, imagen 1 de 3 Xelio P900A-BK Front Facing Camera Replacement: paso 5, imagen 2 de 3 Xelio P900A-BK Front Facing Camera Replacement: paso 5, imagen 3 de 3
    • Use the smaller plastic opening tool to remove the camera from its socket.
Conclusión
Una persona más ha completado esta guía.
Marcus Nelson
Miembro Desde 03/26/15
307 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 112
