Saltar al contenido principal
Xelio P1001A-BK Back Cover Replacement
Qué necesitas
  1. Xelio P1001A-BK Back Cover Replacement, Back Cover: paso 1, imagen 1 de 2 Xelio P1001A-BK Back Cover Replacement, Back Cover: paso 1, imagen 2 de 2
    • Remove the two 3 mm retaining screws from the side of the tablet with a Phillips #0 screwdriver.
  2. Xelio P1001A-BK Back Cover Replacement: paso 2, imagen 1 de 2 Xelio P1001A-BK Back Cover Replacement: paso 2, imagen 2 de 2
    • Insert the plastic opening tool in between the shelf halves and lift the top shelf half to detach the securing tabs.
    • There are four securing tabs located on each long side.
    • Before fully separating the shell halves, observe if the speakers are separated from the shell half. If they are still in their sockets, gently pry them loose with the plastic opening tool.
Conclusión
Una persona más ha completado esta guía.
Josh Saenz
Miembro Desde 03/11/15
316 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 240
