Saltar al contenido principal
Introducción
Follow this guide to remove and replace the fan on a Xbox Series S.
  1. Before you start this guide, turn off the Xbox and unplug any cables from it. Use tweezers to peel off the two white screw covers located on the bottom corners of the back panel. Use tweezers to peel off the two white screw covers located on the bottom corners of the back panel.
    • Before you start this guide, turn off the Xbox and unplug any cables from it.
    • Use tweezers to peel off the two white screw covers located on the bottom corners of the back panel.
    • Use a T8 Torx driver to remove the two 10 mm-long screws securing the back panel to the bottom panel.
  2. Slide the bottom panel horizontally toward the back of the console until it comes to a stop. This slides the clips out of the slots on the plastic case. Lift straight up and remove the bottom panel from the plastic case.
    • Slide the bottom panel horizontally toward the back of the console until it comes to a stop.
    • This slides the clips out of the slots on the plastic case.
    • Lift straight up and remove the bottom panel from the plastic case.
  3. Use a T10 Torx driver to remove the  seven 51 mm-long screws securing the chassis to the plastic case.
    • Use a T10 Torx driver to remove the seven 51 mm-long screws securing the chassis to the plastic case.
  4. With the bottom of the Xbox facing you, pull the two bottom-rear corners of the plastic case away from each other. As you pull the corners apart, slide the back panel towards the bottom of the device. This releases the back panel from  the plastic case. The back panel should now settle on top of the clips on the back of the plastic case.
    • With the bottom of the Xbox facing you, pull the two bottom-rear corners of the plastic case away from each other.
    • As you pull the corners apart, slide the back panel towards the bottom of the device. This releases the back panel from the plastic case.
    • The back panel should now settle on top of the clips on the back of the plastic case.
    • The back panel is permanently attached to the aluminum chassis.
    • Do not attempt to fully remove the chassis from the plastic case with this technique. You may risk breaking your case.
  5. Pull the bottom-left corner away from the chassis while swinging the chassis away from the plastic case. You may need to lift the chassis to free it from the clips on the bottom-front of the plastic case during this process. Remove the plastic case from the chassis.
    • Pull the bottom-left corner away from the chassis while swinging the chassis away from the plastic case.
    • You may need to lift the chassis to free it from the clips on the bottom-front of the plastic case during this process.
    • Remove the plastic case from the chassis.
  6. Use a T10 Torx driver to remove the seven 11.3 mm-long screws securing the power supply to the chassis.
    • Use a T10 Torx driver to remove the seven 11.3 mm-long screws securing the power supply to the chassis.
  7. Flip the device over. Lift the upper chassis straight up to remove it.
    • Flip the device over.
    • Lift the upper chassis straight up to remove it.
  8. Lift the power supply straight up to disconnect it from the motherboard. Remove the power supply. Remove the power supply.
    • Lift the power supply straight up to disconnect it from the motherboard.
    • Remove the power supply.
  9. Use a T10 Torx driver to remove the two 11.3 mm-long screws securing the fan to the chassis.
    • Use a T10 Torx driver to remove the two 11.3 mm-long screws securing the fan to the chassis.
  10. Flip the device over. Take care when flipping the chassis over because the fan is now loose.
    • Take care when flipping the chassis over because the fan is now loose.
    • Use your fingers to pull and disconnect the fan connector from its motherboard socket.
    • Take care not to pull on the wires when disconnecting the fan to prevent breaking the connector.
    • This connector may be difficult to remove. A good method to remove it is to shimmy the connector up and out of its socket with a spudger.
    • You may be able to remove this connector without removing the power supply with a pair of needle-nose pliers.
  11. Lift the fan straight up to remove it from the motherboard. Lift the fan straight up to remove it from the motherboard.
    • Lift the fan straight up to remove it from the motherboard.
Conclusión
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
2 personas más completaron esta guía.
Robert Boyd
Miembro Desde 01/02/21
12,612 Reputación
87 Guías creadas
Equipo
iFixit Miembro de iFixit
Community
137 Miembros
16,682 Guías creadas
Un Comentario
what kind of pin connector does the fan use? i want to see if it’s possible to attach a fan splitter y cable.
Sir Yeeks - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 8
Ultimos 7 días: 48
Ultimos 30 días: 200
Todo El Tiempo: 1,386
