Saltar al contenido principal
Xbox One Wireless Controller Model 1537 Disassembly
Qué necesitas
  1. Xbox One Wireless Controller Model 1537 Disassembly, Controller: paso 1, imagen 1 de 1
    • Remove the battery cover and batteries.
  2. Xbox One Wireless Controller Model 1537 Disassembly: paso 2, imagen 1 de 2 Xbox One Wireless Controller Model 1537 Disassembly: paso 2, imagen 2 de 2
    • Remove the side handles by wedging a spudger in between the front and side panels.
    • To pry the side panel off move the spudger back and forth do this along the entire seam to remove the side panel.
  3. Xbox One Wireless Controller Model 1537 Disassembly: paso 3, imagen 1 de 1
    • Using a T8 security torxs screwdriver remove the five 10mm screws from the back of the controller.
    • One of the screws is hidden behind the label you can either remove the label or poke a hole through it.
  4. Xbox One Wireless Controller Model 1537 Disassembly: paso 4, imagen 1 de 1
    • After removing the screws the front panel should come off easily .
  5. Xbox One Wireless Controller Model 1537 Disassembly: paso 5, imagen 1 de 1
    • Remove the back plate.
Conclusión
3 personas más completaron esta guía.
shiv
Miembro Desde 04/20/18
211 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 21
Ultimos 30 días: 101
Todo El Tiempo: 2,772
