Saltar al contenido principal
Partes
No se especificaron partes.
  1. Remove  the battery cover and batteries.
    • Remove the battery cover and batteries.
  2. Remove the side handles by wedging a spudger in between the front and side panels. To pry the side panel off move the spudger back and forth do this along the entire seam to remove the side panel.
    • Remove the side handles by wedging a spudger in between the front and side panels.
    • To pry the side panel off move the spudger back and forth do this along the entire seam to remove the side panel.
  3. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  4. Using a T8 security torxs screwdriver remove the five 10mm screws from the back of the controller.
    • Using a T8 security torxs screwdriver remove the five 10mm screws from the back of the controller.
    • One of the screws is hidden behind the label you can either remove the label or poke a hole through it.
  5. After removing the screws the front panel should come off easily .
    • After removing the screws the front panel should come off easily .
  6. Remove the back plate.
    • Remove the back plate.
Conclusión
Una persona más ha completado esta guía.
shiv
Miembro Desde 20/04/18
151 Reputación
1 Guía escrita
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 5
Últimos 30 Días: 14
Todo El Tiempo: 822
