Saltar al contenido principal
Xbox One S All Digital Edition Top Metal Shield Replacement
Qué necesitas
  1. Xbox One S All Digital Edition Top Metal Shield Replacement, Plastic Enclosure: paso 1, imagen 1 de 3 Xbox One S All Digital Edition Top Metal Shield Replacement, Plastic Enclosure: paso 1, imagen 2 de 3 Xbox One S All Digital Edition Top Metal Shield Replacement, Plastic Enclosure: paso 1, imagen 3 de 3
    • Position the iFixit Opening Tool's riveted edge in between the top and bottom cover of the plastic enclosure.
    • Apply downward pressure on the iFixit Opening Tool until the security clip unlocks.
    • Repeat on different points of the plastic enclosure until the bottom cover is removed.
  2. Xbox One S All Digital Edition Top Metal Shield Replacement: paso 2, imagen 1 de 2 Xbox One S All Digital Edition Top Metal Shield Replacement: paso 2, imagen 2 de 2
    • Remove the six 50 mm green screws (labeled F1-F6) from the metal chassis using a Torx 10 screwdriver.
    • These screws hold the top cover of the plastic enclosure to the chassis.
  3. Xbox One S All Digital Edition Top Metal Shield Replacement: paso 3, imagen 1 de 2 Xbox One S All Digital Edition Top Metal Shield Replacement: paso 3, imagen 2 de 2
    • Apply pressure to peel off the sides of the casing.
    • Separate the metal chassis from the top cover, lifting the back of the chassis up and away from the top cover.
    • The plastic back panel is meant to stay attached to the metal chassis.
  4. Xbox One S All Digital Edition Top Metal Shield Replacement: paso 4, imagen 1 de 1
    • Flip the metal enclosure so that the fan cover is on top.
  5. Xbox One S All Digital Edition Top Metal Shield Replacement, Top Metal Shield: paso 5, imagen 1 de 2 Xbox One S All Digital Edition Top Metal Shield Replacement, Top Metal Shield: paso 5, imagen 2 de 2
    • Remove the two 15mm screws from the front panel using the Torx T8 screwdriver.
  6. Xbox One S All Digital Edition Top Metal Shield Replacement: paso 6, imagen 1 de 3 Xbox One S All Digital Edition Top Metal Shield Replacement: paso 6, imagen 2 de 3 Xbox One S All Digital Edition Top Metal Shield Replacement: paso 6, imagen 3 de 3
    • Carefully slide the top metal case off the frame.
    • This may require shifting the case side to side as you slide up.
Conclusión
2 personas más completaron esta guía.
Jules Hajjar
Miembro Desde 10/10/19
1,531 Reputación
8 Guías creadas
Equipo
Cal Poly, Team S12-G6, Regan Fall 2019 Miembro de Cal Poly, Team S12-G6, Regan Fall 2019
CPSU-REGAN-F19S12G6
4 Miembros
26 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 13
Todo El Tiempo: 690
