Introducción
This guide will help you replace the motherboard of your Xbox One.
The motherboard houses the processors and connects all the components such as the optical drive, the hard drive, and the Wi-Fi board together.
Note that this replacement requires you to remove the heat sink and fan from the motherboard. Every time you remove the heat sink you should replace the thermal paste that separates it from the motherboard. Be sure to have replacement thermal paste on hand before reassembling the device.
Qué necesitas
Slide the black angled tab behind the silver button toward the back of the console and set it aside.
Remove all eight of the 64.0 mm, T-9 screws labeled C1 through C8 securing the chassis top to the motherboard.
Lift the bottom half of the chassis (motherboard and all) from the bottom half of the black case.
Unplug the red wire connecting the optical drive to the motherboard from its connector on the motherboard.
Unplug the yellow wire connecting the optical drive to the motherboard from its connector on the motherboard.
The optical drive is now free, lift it from the chassis and set it aside.
Unplug the red wire connecting the hard drive to the motherboard from its connector on the motherboard.
Unplug the multi-colored wire connecting the hard drive to the motherboard from its connector on the motherboard.
The hard drive is now free, remove it from the chassis by lifting straight up. Set it aside.
Turn the chassis upside down.
Remove the four black 9.5mm T-9 screws labeled A1, A2, A3, and A4.
Remove the four grey 11.0mm T-9 screws labeled B1, B2, B3, and B4.
Carefully turn the motherboard and fan over so that the fan is facedown.
Firmly wedge the tweezers or a small flathead screwdriver under the edge of the X-shaped spring and lift to release the spring.
Lift the spring free of the pegs and set aside.
8 personas más completaron esta guía.
Un comentario
Thank you very much, your time, effort, and consideration is very much appreciated. Kudos also for the detailed illustrations it lends a level of professionalism not found in many black and white tech guides.
