Introducción
This guide will show you how to replace the action buttons on the Xbox One Elite Controller. Use the Soldering Iron Guide to detach and reattach the wires to the motherboard.
Qué necesitas
Turn over the controller so that the buttons face down.
Remove the battery cover carefully by sliding the cover up in the direction of the arrow.
Remove each grip by inserting the plastic opening tool near the top of the controller.
Guide the plastic opening tool along the entire seam and gently separate the grip from the controller in a prying motion as you go.
Flip the controller so that the buttons are face up to prevent the vibration motors from falling out of the controller.
Remove the D-pad by lifting the bottom and pulling it up.
Remove the entire plastic faceplate by pulling it up gently.
Remove the thumbsticks by pulling them off from the top.
Mark each motor according to where it attaches. The rumble motors are different so they will not work if you switch them.
Turn over the controller so that the thumbsticks are facing down.
Use tweezers and a soldering iron (Soldering Iron Guide) to remove the black and red wires from the motherboard.
Use the T6 Torx screwdriver to remove the two T6 7mm screws located just above the rumble motor housing.
Use the T6 Torx Screwdriver to unscrew the six T6 7mm Torx screws that hold the bottom motherboard to the plastic frame of the controller.
Use the plastic spudger to remove the silver assembly that holds the right and left bumpers, by lifting the plastic tab near the charging port of the Xbox.
Slowly remove the bottom motherboard by pulling it up and towards yourself.
14 personas más completaron esta guía.
Un comentario
Thanks for the guide!
I found two little things that you could improve:
The green part on step 14 does not belong in this place. It is the pairing button. (I can send you a pictore of the correct placement)
The cable connectors are flip up / down ones. so you need to flip them up to reinsert them and they are much easier to remove if you flip them up.
