Saltar al contenido principal
Xbox Hard Drive Management
  1. Xbox Hard Drive Management, Xbox Hard Drive Management: paso 1, imagen 1 de 1
    • Boot up your Xbox without a disc in the drive and you will get the dashboard. Head to "Memory", as the Xbox doesn't have a single format HD option.
  2. Xbox Hard Drive Management: paso 2, imagen 1 de 1
    • Here you can see the Xbox hard drive options. Select the save you want to delete, and hit A.
  3. Xbox Hard Drive Management: paso 3, imagen 1 de 1
    • Press A to delete the save. Then go back and delete all the other saves you want to delete. Now your Xbox HD is completely clear of savegames.
    • If you're selling your Xbox, go to Settings and turn off auto-login and go to Xbox LIVE and remove your account options.
Conclusión
Make sure you haven't left any music on your Xbox HD if you're selling your Xbox.
19 personas más completaron esta guía.
Eddie Meehan
Miembro Desde 09/23/13
867 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 15
Ultimos 30 días: 65
Todo El Tiempo: 10,498
