1. Boot up your Xbox without a disc in the drive and you will get the dashboard. Head to "Memory", as the Xbox doesn't have a single format HD option.
    • Boot up your Xbox without a disc in the drive and you will get the dashboard. Head to "Memory", as the Xbox doesn't have a single format HD option.
  2. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  3. Here you can see the Xbox hard drive options. Select the save you want to delete, and hit A.
    • Here you can see the Xbox hard drive options. Select the save you want to delete, and hit A.
  4. Press A to delete the save. Then go back and delete all the other saves you want to delete. Now your Xbox HD is completely clear of savegames.
    • Press A to delete the save. Then go back and delete all the other saves you want to delete. Now your Xbox HD is completely clear of savegames.
    • If you're selling your Xbox, go to Settings and turn off auto-login and go to Xbox LIVE and remove your account options.
Conclusión
Make sure you haven't left any music on your Xbox HD if you're selling your Xbox.
18 personas más completaron esta guía.
Eddie Meehan
Miembro Desde 23/09/13
840 Reputación
1 Guía escrita
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 13
Últimos 30 Días: 88
Todo El Tiempo: 6,767
