Saltar al contenido principal
Xbox Duke Controller Potentiometer Replacement
Qué necesitas
  1. Xbox Duke Controller Potentiometer Replacement, Face Plate: paso 1, imagen 1 de 3 Xbox Duke Controller Potentiometer Replacement, Face Plate: paso 1, imagen 2 de 3 Xbox Duke Controller Potentiometer Replacement, Face Plate: paso 1, imagen 3 de 3
    • Remove the seven black 8 mm screws holding the two halves of the Duke together using a Phillips #1 screwdriver.
    • To reach the deeply set screws, use a longer screw driver or a 4.0 socket bit in addition to the PH1 bit.
  2. Xbox Duke Controller Potentiometer Replacement: paso 2, imagen 1 de 3 Xbox Duke Controller Potentiometer Replacement: paso 2, imagen 2 de 3 Xbox Duke Controller Potentiometer Replacement: paso 2, imagen 3 de 3
    • Remove the two halves of the Duke, placing the top plate face-down so the buttons don't fall out.
  3. Xbox Duke Controller Potentiometer Replacement, Potentiometer: paso 3, imagen 1 de 2 Xbox Duke Controller Potentiometer Replacement, Potentiometer: paso 3, imagen 2 de 2
    • Remove the stick caps from the potentiometers.
  4. Xbox Duke Controller Potentiometer Replacement: paso 4, imagen 1 de 2 Xbox Duke Controller Potentiometer Replacement: paso 4, imagen 2 de 2
    • Disconnect the connectors attaching the rumble motors to the motherboard using a pair of tweezers.
    • Be gentle when slipping the tweezers underneath the flaps of the connectors; they are fragile and can snap.
  5. Xbox Duke Controller Potentiometer Replacement: paso 5, imagen 1 de 2 Xbox Duke Controller Potentiometer Replacement: paso 5, imagen 2 de 2
    • Using a Phillips #1 screwdriver, remove the four yellow 8 mm screws holding the motherboard to the bottom half of the controller.
  6. Xbox Duke Controller Potentiometer Replacement: paso 6, imagen 1 de 2 Xbox Duke Controller Potentiometer Replacement: paso 6, imagen 2 de 2
    • Remove the motherboard from the bottom half of the controller.
  7. Xbox Duke Controller Potentiometer Replacement: paso 7, imagen 1 de 3 Xbox Duke Controller Potentiometer Replacement: paso 7, imagen 2 de 3 Xbox Duke Controller Potentiometer Replacement: paso 7, imagen 3 de 3
    • Desolder the connector pins holding the left trigger assembly in place.
    • Remove the trigger assembly by pushing on the black connectors that hold them to the motherboard.
  8. Xbox Duke Controller Potentiometer Replacement: paso 8, imagen 1 de 1
    • Desolder all of the connector pins holding the potentiometer in place.
    • Pull out the potentiometers and solder the new ones into place.
Conclusión
Una persona más ha completado esta guía.
Anthony Casino
Miembro Desde 02/15/25
630 Reputación
4 Guías creadas
Equipo
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 13
Ultimos 30 días: 50
Todo El Tiempo: 359
