Introducción
Did the bright green Xbox button stop glowing? Has it lost sensitivity over time? This guide will show you how to open the controller, remove the main circuit board, and replace the Xbox button.
Qué necesitas
Turn the controller on its backside and push the "eject" button to discharge the battery compartment door on the bottom of the controller.
Pull the two AA batteries out.
Remove the holographic Microsoft sticker with the percision tweezers to reveal a small screw.
Use a T6 Torx screwdriver to remove the 1.5mm screw.
Pull the two halves apart at the bottom to detach the two latches that are holding the front and back panels together.
Start with one side of the controller (left or right).
Slide the spudger towards the end of the handles and pry the two halves apart. Do the same for the opposite side.
Pull the front and back panels apart to separate them and expose the inside of the controller.
Lift the battery compartment out of the controller and set it outside of the controller.
Use the precision tweezers to pull out the red and black wire attached to the white plug at the bottom side of the circuit board.
Use precision tweezers to remove the red and black wires that are attached to the circuit board.
Use a T6 Torx screwdriver to remove the four 2.3mm screws.
Lift up the black locking tab on the ZIF connector to release the ribbon cable.
Use a T6 Torx screwdriver to remove the 2.3 mm screw.
Carefully lift and remove the circuit board
Una persona más ha completado esta guía.
