Introducción
Use this guide to replace the bottom panel of your controller that you cracked by throwing it at the TV.
Qué necesitas
Depress the battery release button on the top of the controller.
Remove the battery holder from the controller.
Use the flat end of a spudger to remove the vibration motor cable, moving it upward from its socket on the logic board.
Lift the vibration motor out of the front case.
Lifting from the headphone jack and power plug, remove the logic board from the front case.
16 personas más completaron esta guía.
Un comentario
I have 2 remote controllers of X box one which is not working.
