Introducción
When you can't download the game you just have to have follow this guide to replace your Wi-Fi card.
Qué necesitas
Push the Spudger into the crevice between the grated top panel of the Xbox and the bottom body with the rubber feet.
Pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
Remove the 11 mm screw left of the green wifi-card using the T9 Torx screw bit.
5 personas más completaron esta guía.
