Introducción
This guide provides instructions on how to replace a Xbox 360 controller's cord. Be aware that minimum soldering skills are needed as the controller's circuit board can be permanently damaged if not handled properly.
Before starting this guide, make sure you have:
- micro screwdriver
- soldering iron and wire
- desoldering wick
- replacement USB cord
Qué necesitas
By following these steps, you will be able to replace your Xbox 360 controller's USB cord. Hopefully this guide is useful to you and will elongate the life capacity of your Xbox 360 controller.
35 personas más completaron esta guía.
16 comentarios
http://www.ebay.in/itm/Replacement-USB-C...
Here is where I got mine. Ebay India.
The first one took me 1 hour and half, the second one 20 minutes. Here are some comments.
- It was very hard to unsolder the defective USB plug. I had to use a high temperature on the solder iron, and pull the plug from the other side as I was alternating between the 4 pins.
- There are 4 pins but 5 holes on the board. Make sure to check what one is useless before unsoldering.
- It is best to dismount the controller face down and to keep it that way. The face plate has all the buttons and they will fall if you turn it upside up.
What happen if I disconnect the tumblers
Thank you for this explicitly post.
