Saltar al contenido principal
Introducción
Replace Memory Module
Partes
No se especificaron partes.
  1. CAUTION:  Before you begin the following procedure, follow the safety instructions in the  Product Information Guide .
    • CAUTION: Before you begin the following procedure, follow the safety instructions in the Product Information Guide .
    • NOTICE: To prevent static damage to components inside your computer, discharge static electricity from your body before you touch any of your computer's electronic components. You can do so by touching an unpainted metal surface. If you leave the area, ground yourself again when you return to the computer.
    • NOTE: Memory modules purchased from Dell are covered under your computer warranty.
    • NOTE: To get maximum performance/dual-channel memory bandwidth capability, both memory module connectors must contain memory modules and the modules must be of the same size and configuration.
    • NOTICE: To help prevent damage to the system board, you must remove the main battery before you begin working inside the computer
    • With the computer still turned over, loosen the captive screw on the memory module cover and slide the cover toward the back of the computer to remove it.
  2. NOTICE:  To prevent damage to the memory module connector, do not use tools to spread the memory-module securing clips.
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory-module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
  3. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  4. Remove the module from the connector on the system board.
    • Remove the module from the connector on the system board.
  5. Align the notch on the edge of the memory module connector with the tab in the connector on the system board, and slide the module firmly into the connector at a 45-degree angle.
    • Align the notch on the edge of the memory module connector with the tab in the connector on the system board, and slide the module firmly into the connector at a 45-degree angle.
  6. Rotate the module down until it clicks into place. If you do not feel the click, remove the module and reinstall it.
    • Rotate the module down until it clicks into place. If you do not feel the click, remove the module and reinstall it.
  7. Replace the memory cover. Align the notches in the cover with the tabs on the base, slide the cover toward the front of the computer, and tighten the captive screw.
    • Replace the memory cover. Align the notches in the cover with the tabs on the base, slide the cover toward the front of the computer, and tighten the captive screw.
Linea de Meta
Una persona más ha completado esta guía.
Johnathan Hammond
Miembro Desde 28/02/18
35,861 Reputación
408 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 4
Todo El Tiempo: 53
