Saltar al contenido principal
XMAX V3 Pro Disassembly
Qué necesitas
  1. XMAX V3 Pro Disassembly, Battery Door: paso 1, imagen 1 de 3 XMAX V3 Pro Disassembly, Battery Door: paso 1, imagen 2 de 3 XMAX V3 Pro Disassembly, Battery Door: paso 1, imagen 3 de 3
    • Remove battery door
  2. XMAX V3 Pro Disassembly, Battery Removal: paso 2, imagen 1 de 2 XMAX V3 Pro Disassembly, Battery Removal: paso 2, imagen 2 de 2
    • Remove the battery from the device
  3. XMAX V3 Pro Disassembly, Bottom Cover: paso 3, imagen 1 de 3 XMAX V3 Pro Disassembly, Bottom Cover: paso 3, imagen 2 de 3 XMAX V3 Pro Disassembly, Bottom Cover: paso 3, imagen 3 de 3
    • Apply heat from a hair dryer to help soften the glue
    • Use a spudger to pry off bottom cover
    • This might result in physical damage of the plastic bottom and cover by deforming the material
  4. XMAX V3 Pro Disassembly, Bottom Screws: paso 4, imagen 1 de 2 XMAX V3 Pro Disassembly, Bottom Screws: paso 4, imagen 2 de 2
    • Remove four PH000 screws
    • Remove plastic cover
  5. XMAX V3 Pro Disassembly, Assembly Removal: paso 5, imagen 1 de 3 XMAX V3 Pro Disassembly, Assembly Removal: paso 5, imagen 2 de 3 XMAX V3 Pro Disassembly, Assembly Removal: paso 5, imagen 3 de 3
    • Use your thumb to apple pressure in the direction of the arrow
    • The entire assembly should slide out of the metal case
  6. XMAX V3 Pro Disassembly, Vibration Motor Screws: paso 6, imagen 1 de 1
    • Remove both P00 Screws
  7. XMAX V3 Pro Disassembly, Vibration Motor Removal: paso 7, imagen 1 de 3 XMAX V3 Pro Disassembly, Vibration Motor Removal: paso 7, imagen 2 de 3 XMAX V3 Pro Disassembly, Vibration Motor Removal: paso 7, imagen 3 de 3
    • Use a spudger to remove the vibration motor and spring
  8. XMAX V3 Pro Disassembly, Airflow Overview: paso 8, imagen 1 de 2 XMAX V3 Pro Disassembly, Airflow Overview: paso 8, imagen 2 de 2
    • Here is an overview of the internal assembly on top of the metal case so you can see the airpath
    • The rubber gasket that can be seen better in step 11 stops air from entering the heating assembly from the motherboard area and only allows it to be drawn in the the side perforations.
    • Air enters though the area within the red square and then goes though the hole within the red circle
  9. XMAX V3 Pro Disassembly, Negative Battery Contact Removal: paso 9, imagen 1 de 2 XMAX V3 Pro Disassembly, Negative Battery Contact Removal: paso 9, imagen 2 de 2
    • Use your thumb to push in the gold contact
  10. XMAX V3 Pro Disassembly, Continued Removal of Negative Terminal: paso 10, imagen 1 de 3 XMAX V3 Pro Disassembly, Continued Removal of Negative Terminal: paso 10, imagen 2 de 3 XMAX V3 Pro Disassembly, Continued Removal of Negative Terminal: paso 10, imagen 3 de 3
    • Use a spudger to completely remove the gold battery contact from case
  11. XMAX V3 Pro Disassembly, Airflow Gasket Removal: paso 11, imagen 1 de 2 XMAX V3 Pro Disassembly, Airflow Gasket Removal: paso 11, imagen 2 de 2
    • Remove rubber gasket, simply slide it down the heater assembly
  12. XMAX V3 Pro Disassembly, O-ring Removal: paso 12, imagen 1 de 2 XMAX V3 Pro Disassembly, O-ring Removal: paso 12, imagen 2 de 2
    • Remove rubber o-ring
  13. XMAX V3 Pro Disassembly, Motherboard Screws: paso 13, imagen 1 de 1
    • Remove four P000 screws
  14. XMAX V3 Pro Disassembly, Desolding of Heater Assembly: paso 14, imagen 1 de 3 XMAX V3 Pro Disassembly, Desolding of Heater Assembly: paso 14, imagen 2 de 3 XMAX V3 Pro Disassembly, Desolding of Heater Assembly: paso 14, imagen 3 de 3
    • Desolder positive battery terminal and both heater wires
    • Desolder both temperature probe wires
  15. XMAX V3 Pro Disassembly, Heater Assembly: paso 15, imagen 1 de 2 XMAX V3 Pro Disassembly, Heater Assembly: paso 15, imagen 2 de 2
    • Use your fingers to pull off the heater assembly
  16. XMAX V3 Pro Disassembly, Positive Battery Terminal Assembly: paso 16, imagen 1 de 3 XMAX V3 Pro Disassembly, Positive Battery Terminal Assembly: paso 16, imagen 2 de 3 XMAX V3 Pro Disassembly, Positive Battery Terminal Assembly: paso 16, imagen 3 de 3
    • Remove both P000 screws
    • Pull out positive battery terminal assembly
  17. XMAX V3 Pro Disassembly, Heater Core: paso 17, imagen 1 de 3 XMAX V3 Pro Disassembly, Heater Core: paso 17, imagen 2 de 3 XMAX V3 Pro Disassembly, Heater Core: paso 17, imagen 3 de 3
    • Use a nail or spudger to remove the heater core from the outside housing
    • There will be some epoxy on the bottom of the casing that is securing the wires
    • This epoxy needs to be placed before reassembling the device. It stops air from the electronics and motherboard area from entering your mouth.
  18. XMAX V3 Pro Disassembly, More Heater Assembly Pictures: paso 18, imagen 1 de 2 XMAX V3 Pro Disassembly, More Heater Assembly Pictures: paso 18, imagen 2 de 2
    • Some more photos of the heater assembly
Conclusión
5 personas más completaron esta guía.
ShellingRook27
Miembro Desde 08/21/19
1,975 Reputación
7 Guías creadas
Equipo
Repair For You Miembro de Repair For You
Business
1 Miembro
12 Guías creadas
1 Guide Comment
I wonder how the air gets inside the heater core, it does not seem to have any holes!
WasName - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 59
Ultimos 30 días: 317
Todo El Tiempo: 6,184
