Saltar al contenido principal
X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement
Qué necesitas
  1. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement, Battery: paso 1, imagen 1 de 1
    • Unscrew the two 2.5mm Phillips #00 screws from the middle of the car.
    • Unclip the two clips to remove the battery cover.
  2. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: paso 2, imagen 1 de 1
    • Unplug the battery by pushing on the clip.
  3. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement, Underbody: paso 3, imagen 1 de 1
    • Unscrew the two 2.5mm Phillips #00 screws from each side
  4. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: paso 4, imagen 1 de 1
    • Remove the side skirt covers on each side of the car.
  5. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: paso 5, imagen 1 de 2 X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: paso 5, imagen 2 de 2
    • Lift up and remove the two side skirts.
  6. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: paso 6, imagen 1 de 1
    • Unscrew the two 2.5mm Phillips #00 screws from the front skirt of the car.
  7. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: paso 7, imagen 1 de 1
    • Lift the front part of the underbody and pull it out from the main underbody.
  8. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: paso 8, imagen 1 de 2 X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: paso 8, imagen 2 de 2
    • Unscrew the remaining seven 9mm Phillips #00 screws from the underbody of the car.
    • The second image shows a closer view of the rear three screws
  9. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: paso 9, imagen 1 de 2 X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: paso 9, imagen 2 de 2
    • Lift the main underbody from the shell of the car.
    • Lift up the body to expose the wiring and hardware underneath.
  10. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: paso 10, imagen 1 de 1
    • Remove the reflective sticker from the top of the body.
  11. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: paso 11, imagen 1 de 1
    • Unplug the wire connector.
  12. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement, Steering Column: paso 12, imagen 1 de 3 X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement, Steering Column: paso 12, imagen 2 de 3 X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement, Steering Column: paso 12, imagen 3 de 3
    • Unscrew the three 2.5mm Phillips #00 screws from the white steering column.
    • After removing the three screws, the steering column will pop out of position because of the springs underneath. To reassemble, put the springs back together as shown in picture #3.
  13. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement, Steering Column Spring: paso 13, imagen 1 de 1
    • Remove the three 1.6mm Phillips #000 screws from the black motor casing.
  14. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: paso 14, imagen 1 de 1
    • Remove the front motor and its casing from the chassis of the car.
  15. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: paso 15, imagen 1 de 1
    • Carefully remove the steering column spring.
Conclusión
Una persona más ha completado esta guía.
Liam Martinez
Miembro Desde 04/01/15
562 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 24-3, Lancaster Spring 2015 Miembro de Cal Poly, Team 24-3, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G3
3 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 263
