Saltar al contenido principal
X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement
Qué necesitas
  1. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement, Battery: paso 1, imagen 1 de 1
    • Unscrew the two 2.5mm Phillips #00 screws from the middle of the car.
    • Unclip the two clips to remove the battery cover.
  2. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: paso 2, imagen 1 de 1
    • Unplug the battery by pushing on the clip.
  3. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement, Underbody: paso 3, imagen 1 de 1
    • Unscrew the two 2.5mm Phillips #00 screws from each side
  4. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: paso 4, imagen 1 de 1
    • Remove the side skirt covers on each side of the car.
  5. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: paso 5, imagen 1 de 2 X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: paso 5, imagen 2 de 2
    • Lift up and remove the two side skirts.
  6. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: paso 6, imagen 1 de 1
    • Unscrew the two 2.5mm Phillips #00 screws from the front skirt of the car.
  7. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: paso 7, imagen 1 de 1
    • Lift the front part of the underbody and pull it out from the main underbody.
  8. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: paso 8, imagen 1 de 2 X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: paso 8, imagen 2 de 2
    • Unscrew the remaining seven 9mm Phillips #00 screws from the underbody of the car.
    • The second image shows a closer view of the rear three screws
  9. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: paso 9, imagen 1 de 2 X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: paso 9, imagen 2 de 2
    • Lift the main underbody from the shell of the car.
    • Lift up the body to expose the wiring and hardware underneath.
  10. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: paso 10, imagen 1 de 1
    • Remove the reflective sticker from the top of the body.
  11. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: paso 11, imagen 1 de 1
    • Unplug the wire connector.
  12. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement, Rear Motor: paso 12, imagen 1 de 1
    • Unscrew the two 2.5mm Phillips #00 screws on the white covering of the rear motor casing.
    • There is a plastic casing over the rear motor. Simply remove this plastic covering and proceed.
  13. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: paso 13, imagen 1 de 2 X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: paso 13, imagen 2 de 2
    • Remove all ten 1.6mm Phillips #000 screws from the rear motor casing
    • The first image shows five screws on the side with the circuitry
    • The second image shows five screws on the opposite side of the casing.
  14. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: paso 14, imagen 1 de 1
    • Use a soldering gun to remove the attached wires
Conclusión
Una persona más ha completado esta guía.
Trent Peterson
Miembro Desde 04/01/15
454 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 24-3, Lancaster Spring 2015 Miembro de Cal Poly, Team 24-3, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G3
3 Miembros
9 Guías creadas
Un comentario
what size is the motor
mattsson97 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 5
Todo El Tiempo: 500
