Introducción
The front steering motor provides power to the steering column which turns the wheels to one side. If the car fails to turn to one side or the other, it is possible the front steering motor needs replacement.
Qué necesitas
Unscrew the two 2.5mm Phillips #00 screws from the middle of the car.
Unclip the two clips to remove the battery cover.
Unscrew the three 2.5mm Phillips #00 screws from the white steering column.
Remove the three 1.6mm Phillips #000 screws from the black motor casing
