Saltar al contenido principal
X-Treme Tablet Generation 2 Speaker Replacement
Qué necesitas
  1. X-Treme Tablet Generation 2 Speaker Replacement, Speaker: paso 1, imagen 1 de 1
    • Using a spudger and pry tool, remove the back cover. Start at the top corner, and carefully pry the back cover off of the main body.
    • Continue around the device, being careful to not dislodge the power button.
  2. X-Treme Tablet Generation 2 Speaker Replacement: paso 2, imagen 1 de 2 X-Treme Tablet Generation 2 Speaker Replacement: paso 2, imagen 2 de 2
    • Using a solder vacuum and soldering iron, release the red wire from the motherboard first, then release the black wire.
    • The speaker is held on the back cover with adhesive tape. Using a pry tool, carefully pry the speaker from the back cover.
Conclusión
2 personas más completaron esta guía.
Kristen John
Miembro Desde 01/26/15
125 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 317
