Saltar al contenido principal
X-Treme Tablet Generation 2 Battery Replacement
Qué necesitas
  1. X-Treme Tablet Generation 2 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Start on the edge of the top corner and use a spudger opening tool to carefully pry the back cover off of the main body.
    • Continue prying around the device, being careful to not dislodge the power button.
  2. X-Treme Tablet Generation 2 Battery Replacement: paso 2, imagen 1 de 3 X-Treme Tablet Generation 2 Battery Replacement: paso 2, imagen 2 de 3 X-Treme Tablet Generation 2 Battery Replacement: paso 2, imagen 3 de 3
    • Pull the cloth tape from the battery to free the body of the battery.
    • Use a solder vacuum and soldering iron to release the red, and then the black, wire from the motherboard.
  3. X-Treme Tablet Generation 2 Battery Replacement: paso 3, imagen 1 de 2 X-Treme Tablet Generation 2 Battery Replacement: paso 3, imagen 2 de 2
    • Remove the battery from the device.
    • Insert the new 3.7 V Li-Polymer battery into the device.
    • Use the soldering iron to solder the red, and then the black, wire back to motherboard.
    • Check out our How to Solder and Desolder Connections guide for help with soldering best practices.
Conclusión
2 personas más completaron esta guía.
Mike Longshore
Miembro Desde 01/28/15
125 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,064
