Introducción
This guide will involve the quick removal of one of the wheels to either be replaced or to have the car axis cleaned.
Qué necesitas
Remove the wheel. Begin by grabbing your metal spudger or a guitar pick to pop off the plastic cap in the middle of the wheel.
Use the #2 Phillips screwdriver to remove the 4mm Phillips #2 screw inside the wheel.
From here you should be able to easily pull off the wheel from the car and you're finished!
Una persona más ha completado esta guía.
