Saltar al contenido principal
Wyze WVCR200s Side Brush Replacement
  1. Wyze WVCR200s Side Brush Replacement, Side Brush: paso 1, imagen 1 de 1
    • Flip the vacuum upside down so the underside of the device is facing up.
    • On the upper left of the device, you should see a spinning brush with three arms protruding out. This is the side brush.
  2. Wyze WVCR200s Side Brush Replacement: paso 2, imagen 1 de 1
    • To remove, grab the three arms of the brush and pull upwards. The arms should be tight, but should not require too much force to lift off.
    • Once the brush is off, a square peg that holds the brush should be visible.
    • Place the replacement brush on the square peg, and press down with moderate pressure.
Conclusión
Brendan
Miembro Desde 03/20/23
181 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 15
Todo El Tiempo: 249
