Saltar al contenido principal
Wyze WVCR200s Bumper Replacement
Qué necesitas
  1. Wyze WVCR200s Bumper Replacement, Side Brush: paso 1, imagen 1 de 1
    • Flip the vacuum upside down so the underside of the device is facing up.
    • On the upper left of the device, you should see a spinning brush with three arms protruding out. This is the side brush.
  2. Wyze WVCR200s Bumper Replacement: paso 2, imagen 1 de 1
    • To remove, grab the three arms of the brush and pull upwards. The arms should be tight, but should not require too much force to lift off.
    • Once the brush is off, a square peg that holds the brush should be visible.
    • Place the replacement brush on the square peg, and press down with moderate pressure.
  3. Wyze WVCR200s Bumper Replacement, Bumper: paso 3, imagen 1 de 1
    • Flip the vacuum over.
  4. Wyze WVCR200s Bumper Replacement: paso 4, imagen 1 de 1
    • Use a Phillips screwdriver to remove the six screws along the bottom edge of the bumper.
  5. Wyze WVCR200s Bumper Replacement: paso 5, imagen 1 de 3 Wyze WVCR200s Bumper Replacement: paso 5, imagen 2 de 3 Wyze WVCR200s Bumper Replacement: paso 5, imagen 3 de 3
    • The small plastic connector holding the bumper in place should now be loose. Make sure it's disconnected.
    • Pull the bumper straight off of the vacuum.
Conclusión
Brandon Amado
Miembro Desde 03/20/23
411 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 15
Todo El Tiempo: 117
