Saltar al contenido principal
Wyze WVCR200s Battery Replacement
Qué necesitas
  1. Wyze WVCR200s Battery Replacement, Rotating Brush: paso 1, imagen 1 de 1
    • Flip the vacuum upside down so the bottom is facing up.
    • In the center of the device, you should see the rotating brush that stretches from one wheel to the other.
  2. Wyze WVCR200s Battery Replacement: paso 2, imagen 1 de 2 Wyze WVCR200s Battery Replacement: paso 2, imagen 2 de 2
    • Pinch the blue tabs below the rotating brush towards each other.
    • Lift the plastic housing surrounding the rotating brushing straight up, and the remove it from the vacuum.
  3. Wyze WVCR200s Battery Replacement: paso 3, imagen 1 de 3 Wyze WVCR200s Battery Replacement: paso 3, imagen 2 de 3 Wyze WVCR200s Battery Replacement: paso 3, imagen 3 de 3
    • To remove the rotating brush, lift one end of the brush upwards, and remove.
  4. Wyze WVCR200s Battery Replacement, Battery: paso 4, imagen 1 de 1
    • Use a screwdriver to remove four screws along the edge, just above where the brush was removed.
  5. Wyze WVCR200s Battery Replacement: paso 5, imagen 1 de 1
    • Lift the battery cover up and out of the vacuum.
  6. Wyze WVCR200s Battery Replacement: paso 6, imagen 1 de 2 Wyze WVCR200s Battery Replacement: paso 6, imagen 2 de 2
    • Lift the battery out from underneath the cover.
    • Be careful not to pull or yank the battery out, it is connected by wires to the vacuum port.
    • Carefully disconnect the battery from the vacuum port.
Conclusión
Una persona más ha completado esta guía.
Brandon Amado
Miembro Desde 03/20/23
411 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 33
Ultimos 30 días: 143
Todo El Tiempo: 1,453
