Saltar al contenido principal
Wyze Cam V2 Motherboard Replacement
Qué necesitas
  1. Wyze Cam V2 Motherboard Replacement, Back Panel: paso 1, imagen 1 de 1
    • Open up the camera stand to expose the bottom plate of the camera.
    • Remove two 4 mm silver screws using the Phillips #0 screwdriver.
  2. Wyze Cam V2 Motherboard Replacement: paso 2, imagen 1 de 1
    • Using the iFixit opening tool, carefully pry open the bottom plate to gain access to the camera's internals.
  3. Wyze Cam V2 Motherboard Replacement: paso 3, imagen 1 de 2 Wyze Cam V2 Motherboard Replacement: paso 3, imagen 2 de 2
    • Open up the back panel using the iFixit opening tool and unclip the panel from the rest of the device.
    • Be careful of the charging port while taking it off.
  4. Wyze Cam V2 Motherboard Replacement: paso 4, imagen 1 de 2 Wyze Cam V2 Motherboard Replacement: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    $3.99
  5. Wyze Cam V2 Motherboard Replacement, Motherboard: paso 5, imagen 1 de 1
    • Remove the single 6 mm screw located deep inside the device using a Phillips #000 screwdriver.
    • Carefully remove the motherboard from the device.
  6. Wyze Cam V2 Motherboard Replacement: paso 6, imagen 1 de 1
    • Remove the remaining two 6 mm screws from the motherboard with a Phillips #0 screwdriver.
  7. Wyze Cam V2 Motherboard Replacement: paso 7, imagen 1 de 1
    • Using the precision tweezers, detach the charging port’s motherboard from the camera’s motherboard.
Conclusión
Oluajo
Miembro Desde 09/12/23
243 Reputación
2 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 13
Ultimos 30 días: 38
Todo El Tiempo: 253
