Introducción
The Wyze Cam Camera has a 110º wide angle lens, 8x digital zoom, and enhanced night vision. If your camera quality declines, or stops working you might need to replace it. This guide will walk you through getting your camera replaced.
Qué necesitas
Open up the camera stand to expose the bottom plate of the camera.
Remove two 4 mm silver screws using the Phillips #0 screwdriver.
Herramienta utilizada en este paso:Tweezers$3.99
Using the angled slim tweezers, disconnect the cord and pull it gently off of the motherboard.
Remove the single 6 mm screw located deep inside the device using a Phillips #000 screwdriver.
Carefully remove the motherboard from the device.
Remove four 4 mm screws from the back of the camera using a Phillips #0 screwdriver.
