Saltar al contenido principal
World Dryer Airforce J4-973A3 Server Board Replacement
Qué necesitas
  1. World Dryer Airforce J4-973A3 Server Board Replacement, Server Board: paso 1, imagen 1 de 3 World Dryer Airforce J4-973A3 Server Board Replacement, Server Board: paso 1, imagen 2 de 3 World Dryer Airforce J4-973A3 Server Board Replacement, Server Board: paso 1, imagen 3 de 3
    • Begin by removing both screws and the brushed metal casing. Simply lift up at the indicated area with your hand.
    • The INSTALL and REMOVE indicators may be incorrect, so exercise caution when removing the screws.
  2. World Dryer Airforce J4-973A3 Server Board Replacement: paso 2, imagen 1 de 2 World Dryer Airforce J4-973A3 Server Board Replacement: paso 2, imagen 2 de 2
    • Remove both 3/8" Ph2 screws attached to the grey belt at the top and bottom.
    • Lift the grey belt away. This gives access to the server board.
  3. World Dryer Airforce J4-973A3 Server Board Replacement: paso 3, imagen 1 de 3 World Dryer Airforce J4-973A3 Server Board Replacement: paso 3, imagen 2 de 3 World Dryer Airforce J4-973A3 Server Board Replacement: paso 3, imagen 3 de 3
    • Remove all three 1/2" Ph1 screws connecting the server board to the device.
    • During reassembly, install the screws before reattaching the wires.
  4. World Dryer Airforce J4-973A3 Server Board Replacement: paso 4, imagen 1 de 3 World Dryer Airforce J4-973A3 Server Board Replacement: paso 4, imagen 2 de 3 World Dryer Airforce J4-973A3 Server Board Replacement: paso 4, imagen 3 de 3
    • Use a plastic opening tool to remove the two pink capped wires in the upper left corner of the server board.
    • Use the same tool to dislodge the white capped ribbon bus with the multi-colored wires.
    • After these steps, the server board should easily come off the side of the device.
Conclusión
Blane Hirsh
Miembro Desde 09/17/18
260 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 249
