Saltar al contenido principal
World Dryer Airforce J4-973A3 Sensor Board Replacement
Qué necesitas
  1. World Dryer Airforce J4-973A3 Sensor Board Replacement, Sensor Board: paso 1, imagen 1 de 3 World Dryer Airforce J4-973A3 Sensor Board Replacement, Sensor Board: paso 1, imagen 2 de 3 World Dryer Airforce J4-973A3 Sensor Board Replacement, Sensor Board: paso 1, imagen 3 de 3
    • In order to change the air filter, start with the removal of the outer metal casing.
    • Using the special bit, remove the large screws at the bottom of the casing.
    • To remove the case, lift the indicated spot with your hands.
    • The direction for turning the screws is different than what was indicated on the small sticker above the hole.
  2. World Dryer Airforce J4-973A3 Sensor Board Replacement: paso 2, imagen 1 de 3 World Dryer Airforce J4-973A3 Sensor Board Replacement: paso 2, imagen 2 de 3 World Dryer Airforce J4-973A3 Sensor Board Replacement: paso 2, imagen 3 de 3
    • Remove the 1/2" Ph1 screws at the bottom of the red fan cap.
    • Turn over the unit.
    • Push the red tabs on the back of the unit with medium to heavy pressure, using a plastic opening tool.
    • Carefully remove the cap, to prevent damage to the sensor.
  3. World Dryer Airforce J4-973A3 Sensor Board Replacement: paso 3, imagen 1 de 2 World Dryer Airforce J4-973A3 Sensor Board Replacement: paso 3, imagen 2 de 2
    • Remove both 3/8" Ph2 screws attached to the grey belt at the top and bottom.
    • Lift the grey belt away. This gives access to the server board.
  4. World Dryer Airforce J4-973A3 Sensor Board Replacement: paso 4, imagen 1 de 3 World Dryer Airforce J4-973A3 Sensor Board Replacement: paso 4, imagen 2 de 3 World Dryer Airforce J4-973A3 Sensor Board Replacement: paso 4, imagen 3 de 3
    • Remove the rainbow ribbon cable from the middle circuit board, using a plastic opening tool.
    • Remove the 1/2" Ph1 screw from the center of the circuit board.
  5. World Dryer Airforce J4-973A3 Sensor Board Replacement: paso 5, imagen 1 de 1
    • Carefully remove the sensor board from your device.
Conclusión
Luke Clancy
Miembro Desde 09/17/18
123 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 11
Todo El Tiempo: 619
