Saltar al contenido principal
World Dryer Airforce J4-973A3 Motor Replacement
Qué necesitas
  1. World Dryer Airforce J4-973A3 Motor Replacement, Motor: paso 1, imagen 1 de 3 World Dryer Airforce J4-973A3 Motor Replacement, Motor: paso 1, imagen 2 de 3 World Dryer Airforce J4-973A3 Motor Replacement, Motor: paso 1, imagen 3 de 3
    • To change the motor, start by removing the metal casing.
    • Using the special bit, remove the large screws at the bottom of the casing.
    • To remove the case, lift the indicated spot with your hands.
    • The direction for turning the screws is different than what was indicated on the small sticker above the hole.
  2. World Dryer Airforce J4-973A3 Motor Replacement: paso 2, imagen 1 de 3 World Dryer Airforce J4-973A3 Motor Replacement: paso 2, imagen 2 de 3 World Dryer Airforce J4-973A3 Motor Replacement: paso 2, imagen 3 de 3
    • Remove the three 1/2" Ph1 screws at the bottom of the red fan cap.
    • Turn over the device.
    • Push the red tabs on the back of the unit with medium to heavy pressure, using a small prier.
    • Carefully remove the cap, to prevent damage to the sensor.
  3. World Dryer Airforce J4-973A3 Motor Replacement: paso 3, imagen 1 de 2 World Dryer Airforce J4-973A3 Motor Replacement: paso 3, imagen 2 de 2
    • Remove both 3/8" Ph2 screws attached to the grey belt at the top and bottom.
    • Lift the grey belt away. This gives access to the server board.
  4. World Dryer Airforce J4-973A3 Motor Replacement: paso 4, imagen 1 de 1
    • Use a plastic opening tool to remove the two pink capped wires in the upper left corner of the server board.
  5. World Dryer Airforce J4-973A3 Motor Replacement: paso 5, imagen 1 de 3 World Dryer Airforce J4-973A3 Motor Replacement: paso 5, imagen 2 de 3 World Dryer Airforce J4-973A3 Motor Replacement: paso 5, imagen 3 de 3
    • Remove the brass nut from its bolt using a 10mm wrench.
    • Once the nut is free, disconnect the green wire.
  6. World Dryer Airforce J4-973A3 Motor Replacement: paso 6, imagen 1 de 3 World Dryer Airforce J4-973A3 Motor Replacement: paso 6, imagen 2 de 3 World Dryer Airforce J4-973A3 Motor Replacement: paso 6, imagen 3 de 3
    • Remove the rainbow ribbon cable using a plastic opening tool.
    • Remove the 1/2" Ph1 screw from the center of the circuit board.
  7. World Dryer Airforce J4-973A3 Motor Replacement: paso 7, imagen 1 de 3 World Dryer Airforce J4-973A3 Motor Replacement: paso 7, imagen 2 de 3 World Dryer Airforce J4-973A3 Motor Replacement: paso 7, imagen 3 de 3
    • Remove the four 3/4" Ph2 screws from the back of the device body.
    • Separate the motor housing from the device body.
    • Ensure that all wires connecting the motor housing and motherboard are disconnected before removing the component.
  8. World Dryer Airforce J4-973A3 Motor Replacement: paso 8, imagen 1 de 3 World Dryer Airforce J4-973A3 Motor Replacement: paso 8, imagen 2 de 3 World Dryer Airforce J4-973A3 Motor Replacement: paso 8, imagen 3 de 3
    • Remove the four 1/2" Ph2 screws from the filter.
    • Pull the filter plate away to reveal the motor.
  9. World Dryer Airforce J4-973A3 Motor Replacement: paso 9, imagen 1 de 3 World Dryer Airforce J4-973A3 Motor Replacement: paso 9, imagen 2 de 3 World Dryer Airforce J4-973A3 Motor Replacement: paso 9, imagen 3 de 3
    • Pull the motor out of the housing.
    • Be sure to feed the wires through the slot as you pull the motor out.
Conclusión
Eli Forbes
Miembro Desde 09/17/18
172 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 16
Todo El Tiempo: 280
