Saltar al contenido principal
Wooden Chair Slat Replacement
Qué necesitas
  1. Wooden Chair Slat Replacement, Slat: paso 1, imagen 1 de 3 Wooden Chair Slat Replacement, Slat: paso 1, imagen 2 de 3 Wooden Chair Slat Replacement, Slat: paso 1, imagen 3 de 3
    • Saw off the broken chair slat piece(s).
  2. Wooden Chair Slat Replacement: paso 2, imagen 1 de 2 Wooden Chair Slat Replacement: paso 2, imagen 2 de 2
    • Remove the broken piece from the chair.
    • Sand down the chair where the piece was removed.
  3. Wooden Chair Slat Replacement: paso 3, imagen 1 de 3 Wooden Chair Slat Replacement: paso 3, imagen 2 de 3 Wooden Chair Slat Replacement: paso 3, imagen 3 de 3
    • Measure a wooden dowl similar in size to the chair slat.
    • Mark the measurement on the wooden dowel with a marker.
    • Cut the wooden dowel directly on the marked line.
  4. Wooden Chair Slat Replacement: paso 4, imagen 1 de 3 Wooden Chair Slat Replacement: paso 4, imagen 2 de 3 Wooden Chair Slat Replacement: paso 4, imagen 3 de 3
    • Sand the sawed-off end of the dowel.
    • Apply wood stain to the dowel piece to match the chair's color.
    • Apply wood stain following the direction of the wood grain.
  5. Wooden Chair Slat Replacement: paso 5, imagen 1 de 3 Wooden Chair Slat Replacement: paso 5, imagen 2 de 3 Wooden Chair Slat Replacement: paso 5, imagen 3 de 3
    • Let the wood stain dry.
    • Add wood glue to the top of the new slat piece.
    • Add wood glue to the base of the chair.
  6. Wooden Chair Slat Replacement: paso 6, imagen 1 de 3 Wooden Chair Slat Replacement: paso 6, imagen 2 de 3 Wooden Chair Slat Replacement: paso 6, imagen 3 de 3
    • Insert the new slat piece into the missing space.
    • Add the clamp to keep it in place for at least 30 minutes.
  7. Wooden Chair Slat Replacement: paso 7, imagen 1 de 2 Wooden Chair Slat Replacement: paso 7, imagen 2 de 2
    • Let the slat piece dry for at least 24 hours.
    • The chair is then ready for use.
Linea de Meta
Veronica Shedd
Miembro Desde 04/22/24
145 Reputación
1 Guía escrita
Equipo
UC Davis, Team 2-4, Whithaus Spring 2024 Miembro de UC Davis, Team 2-4, Whithaus Spring 2024
UCD-WHITHAUS-S24S2G4
3 Miembros
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 24
Todo El Tiempo: 46
