Saltar al contenido principal
Wolfgang Puck Pie Maker Disassembly
Qué necesitas
  1. Wolfgang Puck Pie Maker Disassembly, Wolfgang Puck Pie Maker Disassembly: paso 1, imagen 1 de 1
    • Open up the pie maker using the two main handles so it's open as shown in the picture.
  2. Wolfgang Puck Pie Maker Disassembly: paso 2, imagen 1 de 2 Wolfgang Puck Pie Maker Disassembly: paso 2, imagen 2 de 2
    • Remove the four 12.7 mm screws from each handle using a Phillips #2 screwdriver.
    • Remove the inside handle cover.
  3. Wolfgang Puck Pie Maker Disassembly: paso 3, imagen 1 de 2 Wolfgang Puck Pie Maker Disassembly: paso 3, imagen 2 de 2
    • Remove the two 12.7 mm screws from the base of the pie maker using a Phillips #2 screwdriver.
    • This will allow for visibility into the wiring in the base.
  4. Wolfgang Puck Pie Maker Disassembly: paso 4, imagen 1 de 2 Wolfgang Puck Pie Maker Disassembly: paso 4, imagen 2 de 2
    • Remove the four 15.9 mm screws from the hinges using a Phillips #2 screwdriver.
    • Remove the top cover by pulling it off of the device.
  5. Wolfgang Puck Pie Maker Disassembly: paso 5, imagen 1 de 2 Wolfgang Puck Pie Maker Disassembly: paso 5, imagen 2 de 2
    • You now have access to the wiring underneath the top and bottom of the device.
    • To access the wiring, lift the metal burner part out of the base. The wiring will be visible on the opposite side, attached to the heating coil.
    • The temperature sensor can be accessed by lifting the bottom side of the device as shown.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 193
