Saltar al contenido principal
Wolf Gourmet WGTR102S Heat Dial Replacement
Qué necesitas
  1. Wolf Gourmet WGTR102S Heat Dial Replacement, Outer Shell: paso 1, imagen 1 de 1
    • Using a wedge, pry off the rubber pieces on the bottom of each foot of the toaster.
  2. Wolf Gourmet WGTR102S Heat Dial Replacement: paso 2, imagen 1 de 1
    • Remove the eight 8mm screws on each toaster foot using a Tri-point Y1 screwdriver.
  3. Wolf Gourmet WGTR102S Heat Dial Replacement: paso 3, imagen 1 de 1
    • Remove the crumb collector located on the bottom of the toaster.
  4. Wolf Gourmet WGTR102S Heat Dial Replacement: paso 4, imagen 1 de 1
    • Remove the three 8mm screws using the Tri-point Y1 screwdriver.
  5. Wolf Gourmet WGTR102S Heat Dial Replacement: paso 5, imagen 1 de 1
    • Remove the two 8mm screws on the bottom of the slide lever using a Tri-point Y1 screwdriver.
    • Once the screws are removed, detach the black plastic cover on the bottom of the slide lever.
  6. Wolf Gourmet WGTR102S Heat Dial Replacement: paso 6, imagen 1 de 1
    • Remove the final 8mm screw in the slide lever.
    • The lever can now pull away from the entire unit.
  7. Wolf Gourmet WGTR102S Heat Dial Replacement: paso 7, imagen 1 de 1
    • Remove toaster's outer shell by lifting straight up.
    • Slowly remove the outer shell. Disconnect ground wire before fully separating the shell and inner components.
  8. Wolf Gourmet WGTR102S Heat Dial Replacement: paso 8, imagen 1 de 2 Wolf Gourmet WGTR102S Heat Dial Replacement: paso 8, imagen 2 de 2
    • Disconnect the wire cluster that connects the lights and circuit board by pulling apart the two plastic connectors.
    • Remove the outer shell from the device.
  9. Wolf Gourmet WGTR102S Heat Dial Replacement, Heat Dial: paso 9, imagen 1 de 1
    • Remove the two 4mm screws found on each side of the circuit board using a Tri-point Y1 screwdriver.
  10. Wolf Gourmet WGTR102S Heat Dial Replacement: paso 10, imagen 1 de 2 Wolf Gourmet WGTR102S Heat Dial Replacement: paso 10, imagen 2 de 2
    • Remove the circuit board from the device.
Conclusión
Ryan Funchess
Miembro Desde 04/19/18
697 Reputación
5 Guías creadas
Equipo
Cal Poly, Team S22-G5, Maness Spring 2018 Miembro de Cal Poly, Team S22-G5, Maness Spring 2018
CPSU-MANESS-S18S22G5
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 6
Ultimos 30 días: 14
Todo El Tiempo: 470
