Saltar al contenido principal
Withings Smart Body Analyzer Pressure Sensor Replacement
Qué necesitas
  1. Withings Smart Body Analyzer Pressure Sensor Replacement, Withings Smart Body Analyzer Disassembly: paso 1, imagen 1 de 1
    • Push the battery door
    • Open the compartment
    • Gently remove the batteries from their designated positions
    • Place them aside, away from the reach of children
  2. Withings Smart Body Analyzer Pressure Sensor Replacement: paso 2, imagen 1 de 3 Withings Smart Body Analyzer Pressure Sensor Replacement: paso 2, imagen 2 de 3 Withings Smart Body Analyzer Pressure Sensor Replacement: paso 2, imagen 3 de 3
    • With caution, insert the plastic opening tools in between the disk and the glass face
    • It's a tight fit, so don't be afraid to apply a little bit of force
    • As soon as you hear a faint crackling sound, that means that the adhesive is budging out of place
    • Gently rotate the plastic spudger around the disk to get around the adhesive
    • Gently lift the metal disk
    • After the disk has been lifted, a wire and a small copper plate can be seen attached to the back of the disk
    • Carefully remove the wire and plate by peeling back the adhesive sticker that has been positioned around them
  3. Withings Smart Body Analyzer Pressure Sensor Replacement: paso 3, imagen 1 de 2 Withings Smart Body Analyzer Pressure Sensor Replacement: paso 3, imagen 2 de 2
    • After all the above steps have been completed, proceed by removing the glass face
    • Carefully insert a plasic spudger in the small gap that exist in between the glass face and the plastic back
    • Run the plastic spudger all around the scale to increase the gap size
    • Place a plastic spudger in every corner, since the feet of the scale are also attached to the glass face using adhesive
    • Carefully insert the metal spudger underneath the adhesive that is located underneath the feet of the scale, and gently keep pushing until the adhesive is out of place
    • Repeat the above steps four times
    • After all the adhesives has been removed, gently lift the glass face off
  4. Withings Smart Body Analyzer Pressure Sensor Replacement, Pressure Sensor: paso 4, imagen 1 de 1
    • Notice the red and black wires connecting the circuit board to each of the pressure sensors.
    • Using a soldering iron and de-soldering braid, remove the soldered red and black wires from the circuit board
  5. Withings Smart Body Analyzer Pressure Sensor Replacement: paso 5, imagen 1 de 2 Withings Smart Body Analyzer Pressure Sensor Replacement: paso 5, imagen 2 de 2
    • Use a Phillips-head screwdriver to remove the screw from the sensor. There will be two screws per sensor.
  6. Withings Smart Body Analyzer Pressure Sensor Replacement: paso 6, imagen 1 de 2 Withings Smart Body Analyzer Pressure Sensor Replacement: paso 6, imagen 2 de 2
    • Remove any sensors you need and you are now ready to replace or repair depending on your needs.
Conclusión
Una persona más ha completado esta guía.
Equipo
2 comentarios
Where do I get those replacements?
karina - Contestar
where can I buy pressure sensors?
Andrey Kolesov - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 27
Todo El Tiempo: 3,872
